kopit Objavljeno Marec 2, 2007 Deli Objavljeno Marec 2, 2007 Nov zmogljiv, športno oblikovan Guzzi.... Povezava do komentarja Delite na drugih straneh More sharing options...
Port Folio Objavljeno Marec 2, 2007 Deli Objavljeno Marec 2, 2007 novi novi :OK: ... ... ... Povezava do komentarja Delite na drugih straneh More sharing options...
BC Objavljeno Marec 2, 2007 Deli Objavljeno Marec 2, 2007 koliko cilindrov ima pa ta? :slap: Povezava do komentarja Delite na drugih straneh More sharing options...
SiR Objavljeno Marec 2, 2007 Deli Objavljeno Marec 2, 2007 a niso tega že lani predstavili ? Povezava do komentarja Delite na drugih straneh More sharing options...
Port Folio Objavljeno Marec 2, 2007 Deli Objavljeno Marec 2, 2007 Malo za info in ENG General information Model: Moto Guzzi 1200 Sport Year: 2007 Engine and transmission Displacement: 1151.00 ccm (70.23 cubic inches) Engine type: V2 Stroke: 4 Power: 95.00 HP (69.3 kW)) @ 7800 RPM Torque: 100.00 Nm (10.2 kgf-m or 73.8 ft.lbs) @ 6000 RPM Compression: 9.8:1 Bore x stroke: 95.0 x 81.2 mm (3.7 x 3.2 inches) Fuel system: Injection. Multipoint Cooling system: Air Gearbox: 6-speed Transmission type final drive: Chain Starter: Electric Physical measures Dry weight: 229.0 kg (504.9 pounds) Overall length: 2,195 mm (86.4 inches) Overall height: 800 mm (31.5 inches) Ground clearance: 185 mm (7.3 inches) Chassis and dimensions Front tyre dimensions: 120/70-ZR17 Rear tyre dimensions: 180/55-ZR17 Front brakes: Double disc Front brakes diameter: 320 mm (12.6 inches) Rear brakes: Single disc Rear brakes diameter: 282 mm (11.1 inches) Speed and acceleration Power/weight ratio: 0.4148 HP/kg Povezava do komentarja Delite na drugih straneh More sharing options...
kopit Objavljeno Marec 12, 2007 Avtor Deli Objavljeno Marec 12, 2007 Predstavitev: http://www.motosvet.com/izpis.php?cid=3143 Povezava do komentarja Delite na drugih straneh More sharing options...
Avatar Objavljeno Marec 12, 2007 Deli Objavljeno Marec 12, 2007 koliko cilindrov ima pa ta? :slap: Koliko jih pa imajo Guzziji? .) Povezava do komentarja Delite na drugih straneh More sharing options...
BC Objavljeno Marec 12, 2007 Deli Objavljeno Marec 12, 2007 če bereš npr. tole temo ugotoviš, da ima guzzi cilindre in če si pismen to pomeni, da jih ima 3 ali več :slap: . saj sem že tam spraševal, pa so me zbrisali... :lol1: :lol1: Povezava do komentarja Delite na drugih straneh More sharing options...
Kruse Objavljeno Marec 12, 2007 Deli Objavljeno Marec 12, 2007 General information Model: Moto Guzzi 1200 Sport Transmission type final drive: Chain WaLoC! :photo: Povezava do komentarja Delite na drugih straneh More sharing options...
