Zdrawc Objavljeno November 9, 2007 Deli Objavljeno November 9, 2007 Novost iz Moto Morinija za leto 2008 predstavljena na milanskem sejmu Stretching out in front of you is all the road and all the fun you could ever wish for. Moto Morini unveils the first ever Italian enduro veloce. Granpasso has the character of a great sports bike and the comfort of a real enduro. And its 1,187cc Bialbero Corsacorta engine has been optimised to give immense power, immediate response and well-balanced consumption. So you can go anywhere and have all the fun you want. Change direction and choose another way to travel. Engine: Moto Morini Bialbero CorsaCorta V2 87° 1187cc Valves per cyl.: 4 Bore x stroke: 107 x 66 mm Clutch: Multiple-plate clutch in oil bath with antiskipping system and radial mastercylinder Frame: Verlicchi steel tubular trellis Front suspension: Marzocchi upside-down fork with 50 mm Ø legs Rear suspension: Ohlins fully adjustment single shock Front brake: Brembo 298 mm double disc with 2-piston callipers and radial master-cylinder Front Tyre: 110/80 3.00 x 19 Tubeless Rear Tyre: 150/70 4.50 x 17 Tubeless Rims: Excel spoke rims with aluminium channel Dry weight: 198 Kg Tank capacity: 25 litri Moto Morini Granpasso 1200 Povezava do komentarja Delite na drugih straneh More sharing options...
fireball Objavljeno Januar 13, 2008 Deli Objavljeno Januar 13, 2008 (popravljeno) Krasota! Sem se že sam spotaknil ob granpassa in pregledal kar se da na spletu. Ampak nekaj pa nočejo povedat: CENE nikjer je ne najdem, na guglu, yahuju... ni je. Se mi pa zdi ,da bo v rangu Moto Guzzi Norgea ali pa BMW-ja. Upam sicer na najlepše, ampak... še vse, kar mi je blo všeč, je blo najdražje. Pa še to. Kje v naši preljubi Sloveniji bi bil servis. Ne bom trdil, mislim da so Moto Morinijevi motorji pri nas so kot bele gorile :unsure: - strašno redki. Popravljeno Januar 13, 2008. Popravil fireball Povezava do komentarja Delite na drugih straneh More sharing options...
simonsi Objavljeno Januar 13, 2008 Deli Objavljeno Januar 13, 2008 To bolj butični motor in ga moraš tako tudi obravnavati. Je gucijeva varijanta bolj dostopna, čeprav mi je tale bolj všeč. Povezava do komentarja Delite na drugih straneh More sharing options...
jest Objavljeno Januar 14, 2008 Deli Objavljeno Januar 14, 2008 naročen. prihaja začetek junija. Bo tudi za "opštu upotrebu" za dobro zainteresirane firbce z dovoljšnjo dosedanjo dvokolesno kilometražo. Vozil predserijo v fabriki. Zelo lahkoten - v vodljivosti podoben KTM-u ADV 950/990, občutena teža med vožnjo bolj podobna kakemu mega litrskemu Supermotu kot pa kravasti tourer enduri (ala varadero). Glede vlečenja iz nizkih obratov pa je od vsega naštetega korak ali še več pred vsemi iz serije tourer enduro. Morda je skoraj preveč navorast za nekoga z malo izkušenj (pri easy rolanju brez sklopke samo zgolj z gasom potegneš črto pri gasu do konca). Povezava do komentarja Delite na drugih straneh More sharing options...
xenon900 Objavljeno Januar 14, 2008 Deli Objavljeno Januar 14, 2008 TUKAJ ga lahko vidite tudi s kovčki, če je že potovalnik :naughty: Povezava do komentarja Delite na drugih straneh More sharing options...
Balistični Objavljeno Januar 14, 2008 Deli Objavljeno Januar 14, 2008 naročen. prihaja začetek junija. Bo tudi za "opštu upotrebu" za dobro zainteresirane firbce z dovoljšnjo dosedanjo dvokolesno kilometražo. Vozil predserijo v fabriki. Zelo lahkoten - v vodljivosti podoben KTM-u ADV 950/990, občutena teža med vožnjo bolj podobna kakemu mega litrskemu Supermotu kot pa kravasti tourer enduri (ala varadero). Glede vlečenja iz nizkih obratov pa je od vsega naštetega korak ali še več pred vsemi iz serije tourer enduro. Morda je skoraj preveč navorast za nekoga z malo izkušenj (pri easy rolanju brez sklopke samo zgolj z gasom potegneš črto pri gasu do konca). Ni kaj, lepo mašino si nabavil. Vendar bo čakanje do junija ubijalsko :whistle: . Povezava do komentarja Delite na drugih straneh More sharing options...
Ice Objavljeno Januar 17, 2008 Deli Objavljeno Januar 17, 2008 masina je iz corsara 1200. glede na doziveto na testni voznji ......*gulp* :blink: . :yea1: :naughty: Povezava do komentarja Delite na drugih straneh More sharing options...
pjotr Objavljeno Januar 17, 2008 Deli Objavljeno Januar 17, 2008 Je morda ABS kot opcija? Zgleda res fajn, pa tudi karakteristike navdušujejo. Slaba stran je gotovo servisna mreža, rok dobave in posledično roki dobav nadomestnih delov (gre pol sezone mimo preden dobiš željen nadomestni del). Povezava do komentarja Delite na drugih straneh More sharing options...
simonsi Objavljeno Januar 17, 2008 Deli Objavljeno Januar 17, 2008 masina je iz corsara 1200.glede na doziveto na testni voznji ......*gulp* :blink: . :yea1: :naughty: Daj malo bolj opiši tale gulp, ne samo drobtinice ponujat. :naughty: Povezava do komentarja Delite na drugih straneh More sharing options...
Barth Objavljeno Januar 17, 2008 Deli Objavljeno Januar 17, 2008 jaz sem gledal en test na neki nemški televiziji, corsaro 1200 je imel med testom probleme z mašino, cukala (med vožnjo v ovinek je blo sploh veselje), crkovala tudi med vožnjo (ne samo pod štantgasom), pa še neke malenkosti okoli kvalitete izdelave in šlamparije. Čez ostalo niso pizdili, ker so imeli preveč ''veselja'' z mašino. Povezava do komentarja Delite na drugih straneh More sharing options...
Ice Objavljeno Januar 21, 2008 Deli Objavljeno Januar 21, 2008 Daj malo bolj opiši tale gulp, ne samo drobtinice ponujat. :naughty: hja, neko "normalno" speljevanje je bilo vec ali manj nemogoce - ali wheely ali burn-out (na mokro/mastni podlagi). navora uiber-dovolj, masina zvezna, fantazija. samo zebe bolj kot na mojem (ker corsaro nima sipe :P ). za vec pa ni bilo (ne casa in ne vremena). Povezava do komentarja Delite na drugih straneh More sharing options...
Guest pmali Objavljeno November 4, 2008 Deli Objavljeno November 4, 2008 naročen. prihaja začetek junija. Bo tudi za "opštu upotrebu" za dobro zainteresirane firbce z dovoljšnjo dosedanjo dvokolesno kilometražo. Vozil predserijo v fabriki. Zelo lahkoten - v vodljivosti podoben KTM-u ADV 950/990, občutena teža med vožnjo bolj podobna kakemu mega litrskemu Supermotu kot pa kravasti tourer enduri (ala varadero). Glede vlečenja iz nizkih obratov pa je od vsega naštetega korak ali še več pred vsemi iz serije tourer enduro. Morda je skoraj preveč navorast za nekoga z malo izkušenj (pri easy rolanju brez sklopke samo zgolj z gasom potegneš črto pri gasu do konca). Kaj si tega grandpaso-ta dubu al ne? dej mal povej kako teče mašina, baje jih sam ene 700 na let nardijo? Povezava do komentarja Delite na drugih straneh More sharing options...
baddad Objavljeno November 4, 2008 Deli Objavljeno November 4, 2008 Multistrada, Stelvio, Granpasso.... "vrhunci" talijanskega dizajna. :naughty: Sploh ni čudno, da BMW proda tolk motorjev v Italiji. Povezava do komentarja Delite na drugih straneh More sharing options...
jest Objavljeno November 8, 2008 Deli Objavljeno November 8, 2008 Multistrada, Stelvio, Granpasso.... "vrhunci" talijanskega dizajna. :naughty: Sploh ni čudno, da BMW proda tolk motorjev v Italiji. Če oz.ko pelješ granpassa ti šele postane čudno zakaj za vraga pa res prodajo tolko GS-ov. Bi blo potrebno uporabit test s sladoledom (natakneš vrečo na glavo in okušaš). Povezava do komentarja Delite na drugih straneh More sharing options...
Guest pmali Objavljeno November 8, 2008 Deli Objavljeno November 8, 2008 Če oz.ko pelješ granpassa ti šele postane čudno zakaj za vraga pa res prodajo tolko GS-ov. Bi blo potrebno uporabit test s sladoledom (natakneš vrečo na glavo in okušaš). A se bo dal kakšno probo kdaj naredit? Povezava do komentarja Delite na drugih straneh More sharing options...
jest Objavljeno November 9, 2008 Deli Objavljeno November 9, 2008 A se bo dal kakšno probo kdaj naredit? Se je že dalo in se še bo! Povezava do komentarja Delite na drugih straneh More sharing options...
biker77 Objavljeno November 9, 2008 Deli Objavljeno November 9, 2008 Se je že dalo in se še bo! kdaj in kje? mogoče tudi corsaro?(veloce) Povezava do komentarja Delite na drugih straneh More sharing options...
