BaTeMaN Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 Prijatelj kupuje ta motocikel, pa me zanima vaše mnenje o njem. Prej je 20.000km naredil na ZX6R-u. Jaz objavljam le opis iz uradne strani: The characteristic layout of the Tornado Tre 900 is unconventional for a road based motorcycle, due to the radiator being positioned underneath the seat, supplied by lateral air intake ducts. This revolutionary idea makes it possible to move the engine forwards, ensuring optimum weight distribution and thus improved riding stability. The engine is a pre-stressed, integral part of the frame, thus further increasing overall rigidity. The frame can be adjusted in terms of both steering head angle and swingarm mounting position; it comprises of a front part in tubular Molybdenum Chrome steel, and a rear in cast aluminium alloy which imposingly embraces the structure. The two parts are solidly linked by means of robust screws pulling on the four trusses, reinforced by a structural bonding, to exclude micro-movements and vibrations completely. Povezava do komentarja Delite na drugih straneh More sharing options...
Einherjar Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 Razen da izgleda lep, ti drugega ne morem povedati... Povezava do komentarja Delite na drugih straneh More sharing options...
simon Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 jest bi takoj kupu. Kolk pa to drgač stane? Povezava do komentarja Delite na drugih straneh More sharing options...
suzuki Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 Če kaj verjameš testom revije Motorrad; tam motorček ni bil preveč pohvaljen. Vse podrobnosti v testu v 23 številki iz leta 2002, stran 10 ali na: http://www.motorradonline.de/LTR/archiv.asp?ID=3 , izberi Freie Suche in nato vtipkaj Benelli... Cena za Limited Edition 32.600 EUR, Biposto 17.000 EUR (vir: Motorrad). Povezava do komentarja Delite na drugih straneh More sharing options...
Einherjar Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 Pa a se da to sploh v Sloveniji nabavit? Povezava do komentarja Delite na drugih straneh More sharing options...
pero Objavljeno Januar 17, 2003 Deli Objavljeno Januar 17, 2003 Zelo lep :!: :!: :!: Ampak jest ne verjamem v neko kvazi obujanje nekoč!!! zelo zvenečih imen motociklistične industrije!!! Upajmo da je tudi tako kvaliteten kot je lep sam s ceno pa vseen pretiravajo!Zanimiva rešitev ventilatorjev pod sedežev amapak ne vem če se bo obneslo!!! Zadeva za v galerijo in manj za na cesto!!! Ciao,by Pero Povezava do komentarja Delite na drugih straneh More sharing options...
Hanzi Objavljeno Januar 19, 2003 Deli Objavljeno Januar 19, 2003 Zadeva se (je) prodaja pri nas! Uvoznik je isti kot za skuterje Benelli in je iz Šmarce pri Kamniku! Koliko pa so jih prodali glede na ceno je pa drugo vprašanje in kakšen je rok dobave! Povezava do komentarja Delite na drugih straneh More sharing options...
vrho1679 Objavljeno Januar 19, 2003 Deli Objavljeno Januar 19, 2003 Motor mi je všečen, najbrž ima tudi dober zvok in je luštn za pelat. Glede na ceno moram reč da je slab. Ne vem kaj mislijo s temi imeni, limited edition serijami in v nebo nažganimi cenami Italjani doseč, če pa za pol manj denarja dobiš pol boljšega Japonca v skoraj vseh pogledih :?: Povezava do komentarja Delite na drugih straneh More sharing options...
pero Objavljeno Januar 19, 2003 Deli Objavljeno Januar 19, 2003 Lepota ni vse predvsem zato k mine! Če ne prej ob prvem podrsanju plastike!!Kaj pa servisi?? Ciao,by Pero Povezava do komentarja Delite na drugih straneh More sharing options...
klemens Objavljeno Januar 19, 2003 Deli Objavljeno Januar 19, 2003 Motor mi je všečen, najbrž ima tudi dober zvok in je luštn za pelat. Glede na ceno moram reč da je slab. Ne vem kaj mislijo s temi imeni, limited edition serijami in v nebo nažganimi cenami Italjani doseč, če pa za pol manj denarja dobiš pol boljšega Japonca v skoraj vseh pogledih :?: Ampak te "japonce" ima že cel kup ljudi, verjetno že kar v ulici. Pri takih motociklih se plača nekaj "ekskluzivnosti", dobiš pa motor ki ni parkiran na vsakem parkirišču. Za nekatere je to veliko. Povezava do komentarja Delite na drugih straneh More sharing options...
king4ever Objavljeno Januar 19, 2003 Deli Objavljeno Januar 19, 2003 Motor mi je všečen, najbrž ima tudi dober zvok in je luštn za pelat. Glede na ceno moram reč da je slab. Ne vem kaj mislijo s temi imeni, limited edition serijami in v nebo nažganimi cenami Italjani doseč, če pa za pol manj denarja dobiš pol boljšega Japonca v skoraj vseh pogledih :?: Ampak te "japonce" ima že cel kup ljudi, verjetno že kar v ulici. Pri takih motociklih se plača nekaj "ekskluzivnosti", dobiš pa motor ki ni parkiran na vsakem parkirišču. Za nekatere je to veliko. Ja in za ekskluzivnost se vozis potem cca 500 km na servis, deli so tak ali tak vprasanje, ze za japonce se jih vcasih tezko dobi, za te italjanare pa ziher se tezje, pa ceprav mamo Italijo skoraj pred nosom. Saj res da je lep in nekaj posebnega, samo moras malo bolj dolgorocno razmisljat. No, sicer pa ni problem ce ima zadosti debelo denarnico. Povezava do komentarja Delite na drugih straneh More sharing options...
