Skeletor Objavljeno Marec 21, 2013 Objavljeno Marec 21, 2013 Živjo! Ali se je že kdo ukvarjal z montažo quick shifter-ja in sicer, imam powercomander5 ter modul za izklop vseh 8 injektorjev, vse skupaj je od dynojeta. Sedaj pa imam problem, imam stikalo pk-power, ki je očitno namenjen pc-3 :angry: . Je že kdo kdaj poskušal kaj predelati in če slučajno kdo ve v čem sta si sistema (stikala) različna. lp!
GrCaR Objavljeno Marec 21, 2013 Objavljeno Marec 21, 2013 (popravljeno) jst pa vem, jst pa vem uglavn za ostale: V powercommanderju je treba nastavit na Normally Open, pol pa dela :grim To Configure Quick Shifter The Quick Shifter accessory for the Power Commander V, when enabled and set-up, will kill engine power for a moment when the shift lever is actuated, allowing full throttle shifts without the clutch. 1 Select Power Commander Tools >Configure >Feature Enables and Selection Inputs. 2 Select the On/Off box to enable or disable Quick Shifter. 3 Using the drop-down arrow, select which switch input will be used. For more information, refer to Power Commander V Switch Inputs. 4 Click Configure to open the Quick Shifter Configuration window. 5 Using the drop-down arrow, select a Mode. Single Time—uses the same shift kill time for all shifts. Gear Dependent—allows a different shift kill time for each gear change. Gear Dependent requires a gear indicator set-up. For more information, refer to To Calibrate the Gear Position. 6 Using the drop-down arrow, select a Switch Style. In most cases the Power Commander V is configured correctly for the Switch Style. Normally Closed—use this setting for a Quick Shifter switch that is in the closed state at rest. Normally Open—use this setting for a Quick Shifter switch that is in the open state at rest. Contact Dynojet for more information. 7 Enter a Minimum RPM. Below the Minimum RPM, the Quick Shift will not function. 8 Enter a Shift Interval. The Shift Interval is the minimum time between each shift. If a second shift event occurs sooner than the length of time set here, it will be ignored. 9 Enter the Shift Kill times. The Shift Kill Time is the amount of time (in milliseconds, 1000mS=1 second) that engine power will be cut for one shift event. If you selected Gear Dependent mode, set a shift kill time for each gear change. 10 Using the drop-down arrow, select a Kill Mode. Kill Fuel Only—interrupts fuel delivery during Quick Shift (including the secondary fuel module, if connected). Kill Ignition Only—interrupts spark delivery during Quick Shift. Kill Fuel and Ignition—interrupts fuel delivery (including the secondary fuel module, if connected) and interrupts spark delivery during Quick Shift. 11 Click OK to accept the changes. Or Click Cancel to close the window without changes. Popravljeno Marec 21, 2013. Popravil GrCaR
Cufa Objavljeno Marec 22, 2013 Objavljeno Marec 22, 2013 http://www.motosvet.com/tabla/topic/32124-quickshifter/?hl=quickshifter
