ICE_MAN Objavljeno April 19, 2004 Deli Objavljeno April 19, 2004 Zanima me motor Kawasaki GPX 750R, ce ga kdo ima kaksn je motor vodljivost, poraba... Kaksni so bli problemi ce so bli ,vzdrzljivost in vse na to temo. Pa kok bi me priblizn generalna stala pa kako je z deli? Spec: Engine Type Liquid-cooled, 4 stroke, 4 cylinder, DOHC 16 valve Bore & Stroke 68.0 x 51.5 mm (2.68 X 2.03 in.) Displacement 748 mL (45.6 cu. In.) Compression Ratio 11.2 to 1 Valve Train 16 valve Maximum horsepower 106 bhp @ 10,500 rpm 85bhp at rear wheel Maximum torque 56 ft/lb @ 8,500 rpm Carburetion Keihin CVK34 x4 Ignition Battery and coil (transistorized ignition) Timing 10 degrees BTDC @1,000 rpm ~ 35 degrees BTDC @3,500 rpm Idle Speed 1,000 +/- 50 rpm Lubrication Forced lubrication (wet sump) Clutch Wet multi disc Transmission 6 speed, constant mesh, return shift Transmission ratios 1st 2.923 2nd 2.125 3rd 1.666 4th 1.380 5th 1.217 6th 1.083 Final Reduction Ratio 2.937 Drive sprocket 16T Driven sprocket 47T Starting system Electric starter only Battery 12V 14 AH Alternator Firing Order 1-2-4-3 Cylinder numbering Left to right, 1-2-3-4 Wheelbase 1,460 mm (57.48 in) Castor 27 degrees Trail 97mm (3.8in) Front suspension Telescopic Forks Travel Air pressure 0 (not adjustable) Rear suspension Swingarm with single shock absorber Travel Air pressure 0 to 21 psi Front tire 110/90V16 Rear tire 140/70V18 or 140/70VB18 Seat height 775mm (30.5 in) Ground clearance 150 mm (5.91 in) Overall height 1,185 mm (46.65 in) Overall width (handlebar) 715 mm (28.1 in) Overall length 2,115 mm (83.27 in) Weight (dry) 195 kg (430 lb) Weight (curb) 225 kg (496 lb) Vehicle capacity load 182 kg (400 lb) Fuel capacity 21 liters (5.5 US gal.) Fuel capacity (reserve) 0 (No reserve) Oil capacity Oil and filter change 3.2 liters (3.4 US qt.) At overhaul 3.8 liters (4.0 US qt.) Coolant capacity 2.0 liters (2.1 US qt.) Front fork oil capacity (each leg) Dry fill 380 +/- 4cc At oil change Approx. 325 cc Povezava do komentarja Delite na drugih straneh More sharing options...
majnk Objavljeno December 13, 2004 Deli Objavljeno December 13, 2004 če ima kdo kakršen koli del za motr od GPX-a naj se mi prosim oglasi...trenutno pa najbolj rabim odmično gred na sesalnih ventili... LP Majnk Povezava do komentarja Delite na drugih straneh More sharing options...
Tomy_ Objavljeno Avgust 25, 2005 Deli Objavljeno Avgust 25, 2005 Zdravo Prvo bi pohvalu forum, berem ga že kar lep čas, zdej se je pojavlo pa tudi prvo vprašanje. Možnost imam kupit GPZ 750r letnik 87, zdej pa mene zanima vse v zvezi s takim motorjem. Prevoženih ima okoli 50k kilometrov, baje nove gume, akumolator, zavore... Zanimajo me vse slabosti tega motorja, njegove hibe, je pa to prvi težji motor v moji karieri. Prej sem meu yamaho sr 125, zdej pa je čas za nekaj močnejšega. Pa zanima me še kakšna je kej realna cena če je motor v brezhibnem stanju Upam na čimveč odgovorov, hvala! LP Simon Povezava do komentarja Delite na drugih straneh More sharing options...
simonsi Objavljeno Avgust 25, 2005 Deli Objavljeno Avgust 25, 2005 Kvečjemu ima kakih 150000 km, pa pri tako starem motorju je lahko vse zanič, pri dobro ohranjenem pa vsaj pol. Če je cena res zelo ugodna in znaš kaj šraufat potem mogoče. :hmm: Glede moči naj te ne skrbi, ampak bolj okretnost, voznost in zavore. Povezava do komentarja Delite na drugih straneh More sharing options...
mkosir Objavljeno Avgust 25, 2005 Deli Objavljeno Avgust 25, 2005 Joj, dej dvakrat premisl preden se v kej takega spustiš. Ker če je z mašino kaj narobe za bit kr komplicirano. Sam sem bil precej zagret za Z1000 letnik 1984 pa mi je mehanik toplo odsvetoval, ker so novi deli precej dragi kot za nov motocikel. Alternativa so odpadi sam... <_< No ja to je moje mnenje. Odločit se boš moral pa sam. Veliko sreče pri nakupih lp Povezava do komentarja Delite na drugih straneh More sharing options...
motolover Objavljeno Avgust 25, 2005 Deli Objavljeno Avgust 25, 2005 Če pa se prav spomnim je model GPX prišel ven 88. Katerega zdaj kupuješ GPX ali GPZ? Jaz sem imel GPX, kupil sem novega 89 in ga je v ovinkih hudo zvijalo. Povezava do komentarja Delite na drugih straneh More sharing options...
vrho1679 Objavljeno Avgust 26, 2005 Deli Objavljeno Avgust 26, 2005 (popravljeno) Ne vem zakaj ste temi združili? GPz in GPX sta različna motorja. Za Tomy: motor je dovolj močan, ima pa kar precej kg in dvomim, da bi bil primeren za prvega resnega motorja. Če je zares lepo ohranjen se ga bolj splača ljubiteljsko vozit in ohraniti naprej, če ni pa pričakuj da se boš več prešraufal kot prevozil. Popravljeno Avgust 26, 2005. Popravil Rok Povezava do komentarja Delite na drugih straneh More sharing options...
Ice Objavljeno Avgust 26, 2005 Deli Objavljeno Avgust 26, 2005 zato, ker je bil naslov na novo odprte teme Kwak GPX. se kaksno vprasanje? Povezava do komentarja Delite na drugih straneh More sharing options...
simonsi Objavljeno Avgust 26, 2005 Deli Objavljeno Avgust 26, 2005 A v Top Gun-u je bil pa GPX 900? Povezava do komentarja Delite na drugih straneh More sharing options...
motolover Objavljeno Avgust 26, 2005 Deli Objavljeno Avgust 26, 2005 Mislim, da se je takrat imenoval GPZ 900R. Povezava do komentarja Delite na drugih straneh More sharing options...
Tomy_ Objavljeno Avgust 26, 2005 Deli Objavljeno Avgust 26, 2005 Hei Motor je GPX 750r verjetno se je lastnik zmotil pri letniku in je 88 ne 87... Hvala za vse odgovore, za nakup se pa verjetno ne bom odločil ker potegne preveč stroškov zasaba (komplet motoristična oprema, servis, registracija). Drugače je pa cena 1000evrov, se vam zdi primerna? LP Simon Povezava do komentarja Delite na drugih straneh More sharing options...
strom Objavljeno Avgust 27, 2005 Deli Objavljeno Avgust 27, 2005 A v Top Gun-u je bil pa GPX 900? ← GPz 750 je bil. Če je motor tipitopi pa vse dela kot more in da se letos samo voziš brez ostalih stroškov, je cena OK. Bremze majo tile super, samo ploščice morjo bit taprave. Vsaj jest sem bil blazno zadovoln z lucasovimi na GPz 600R. Definitivno bolj primerna zadeva za začetek kot pa kakšna cbr600 ipd... A na 125 pa nisi rabil opreme? LP Povezava do komentarja Delite na drugih straneh More sharing options...
BAD PIT Objavljeno Junij 1, 2006 Deli Objavljeno Junij 1, 2006 evo ga gpx 750,letnik 88,proizveden za italijanski trg - baje jih je v Franciji le še peščica,tako mi je reku kolega,ki se je prpelov iz Pariza. Motor ima okoli 56k prevoženih in zaenkrat dela ko urca,sam k je mašina mal prveč brutalna za tist gištel. Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Maj 18, 2009 Deli Objavljeno Maj 18, 2009 ve mogoče kdo za tak motor, kolega rabi neke dele stikalo za bremzo sprednjo, desni pokrov glavni gredi, ... Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Maj 20, 2009 Deli Objavljeno Maj 20, 2009 ima kdo sploh takšen motor še ? vozi se tak neoben ne več z njim kot izgleda Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Maj 26, 2009 Deli Objavljeno Maj 26, 2009 lahko sem mi javi lastnik ene take mašine ? Povezava do komentarja Delite na drugih straneh More sharing options...
simonsi Objavljeno Maj 26, 2009 Deli Objavljeno Maj 26, 2009 gpz-ja 900 sem kar intimno spoznal, če kaj pomaga... Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Maj 29, 2009 Deli Objavljeno Maj 29, 2009 iščem strikno tak motor, bi poskusil 1 del, CDi Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Junij 8, 2009 Deli Objavljeno Junij 8, 2009 al pa ve kdo da se kje vozi tak motor, oz ve da bi ga kdo imel Povezava do komentarja Delite na drugih straneh More sharing options...
Prevtzer Objavljeno Junij 8, 2009 Deli Objavljeno Junij 8, 2009 al pa ve kdo da se kje vozi tak motor, oz ve da bi ga kdo imel Danes sem ga videl v Lj, tak temen. Povezava do komentarja Delite na drugih straneh More sharing options...
stuhec Objavljeno Junij 15, 2009 Deli Objavljeno Junij 15, 2009 Danes sem ga videl v Lj, tak temen. nič ne veš kdo bi lahk bil ali vsaj št.tablice Povezava do komentarja Delite na drugih straneh More sharing options...
