-pero- Objavljeno September 23, 2004 Deli Objavljeno September 23, 2004 2005 Kawasaki ZZR600 (From Kawasaki's press material) NEW ZZR®600 PROVIDES STYLE, COMFORT AND NINJA® PERFORMANCE The Kawasaki ZZR600 motorcycle is dramatically changed for 2005, and will strongly appeal to sportbike riders of all skill levels and especially first-time buyers. Based on a previous generation NINJA® ZX-6R sportbike, the new ZZR600 features a confidence-inspiring aluminum chassis, high-performance engine, 4-into-2- into-1 exhaust system, powerful six-piston brakes, sleek body work and dual headlights. As such, it offers an unbeatable combination of style and performance, yet it's comfortable for daily commuting and weekend getaways. The 599cc, liquid-cooled, inline, four-cylinder engine features dual overhead cams and four valves per cylinder. Kawasaki's Twin Ram Air Induction system - which features a leading-edge air scoop at the front of the bike's fairing - forces cool air into the ZZR600's airbox and then onto its four 36mm carburetors. The carburetors also feature the Kawasaki Throttle Responsive Ignition Control (K-TRIC), which monitors the throttle position and adjusts ignition timing for the engine's four spark-plug mounted ignition coils, maximizing the ZZR's performance at every rpm. The ZZR600's engine is matched to a close-ratio six-speed transmission, providing the rider with the best gear for any riding situation, whether it be freeway droning or sporty backroad work. A lightweight aluminum perimeter frame provides the backbone of the ZZR600's chassis, while suspension duties are handled by a fully adjustable 46mm cartridge-type front fork and fully adjustable UNI-TRAK® rear suspension. Stopping power is provided by six-piston calipers gripping dual 300mm semifloating front disc brakes, matched by a 220mm rear disc brake. The ZZR600 is shod with high-performance radial tires mounted on 17-inch aluminum wheels. The 120/65ZR17 front and 180/55ZR17 rear tires provide maximum traction and help provide a smooth ride over bumpy surface streets and freeway expansion joints. The simple, sleek lines of the ZZR600's aerodynamic body work are distinctly Kawasaki in appearance and pleasing to the eye. Available in (name of color) Blue for 2005, it strikes an elegant-but-athletic balance with the extruded aluminum frame, angled front fairing, purposeful air scoop and three-spoke wheels. The ZZR600's ergonomics make long-distance rides a pleasure: The stepped seat is flat to enhance operator and passenger comfort, and the bars are an easy reach. Plus, the wide mirrors provide the operator with an exceptional view. The instrument cluster for the ZZR600 is entirely electronic and includes a speedometer, tachometer, coolant temperature gauge, odometer, trip meter and - one of the most desirable of features - a digital clock. Authentic Kawasaki Accessories for the ZZR600 are available through Kawasaki dealers or they can be purchased on the Internet at www.buykawasaki.com. Kawasaki Motors Corp., U.S.A. (KMC) markets and sells at wholesale Kawasaki motorcycles, ATVs, personal watercraft, utility vehicles, power products and general purpose engines. These product lines are sold through a network of more than 1,500 independent retailers. KMC and its affiliates employ nearly 2,400 people in the United States, with approximately 400 of them located at the Irvine, California headquarters. Kawasaki's tagline, "Let the good times roll", is recognized worldwide and the brand is aggressively carrying its heritage of power, performance, leading-edge design and exhilaration into the 21st century. Information about Kawasaki's complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com. Features and Benefits 599cc Four-Cylinder DOHC Engine * To decrease engine weight and improve heat transfer, the cylinders have linerless, electroplated aluminum bores * The combustion chamber uses a pentroof/semi-hemi design with a higher compression ratio for more low end torque ad more power throughout the rev range * The alternator, sump, cylinder head, clutch, and cam chain covers are magnesium to cut weight Liquid Cooling * The automatic fan is on the left side of the curved aluminum radiator to save space * Includes an LCD temperature gauge * A liquid-cooled oil cooler helps keep the oil cool Twin Ram Air Induction * Large ducts for more air pressure, which increases high speed power * The extended opening increases pressure in the system for excellent volumetric efficiency Kawasaki Throttle Responsive Ignition Control (K-TRIC) * A throttle position sensor (TPS) tells the ignition unit how hard the engine is working so it can set the best ignition timing Transistor Controlled Breakerless Ignition with Digital Advance * A 16-bit central processing unit responds more quickly to engine needs * Never needs adjustment * The rotor has 12 projections to update the processor often Spark Plug-Mounted Ignition Coils * Four small ignition coils are in the spark plug caps to reduce overall weight, take up less room, and provide strong, consistent spark Catalyzer * To meet emissions limits and make even more power at the same time, both California and 49-state models have a pre-catalyzer in the pipe leading to the muffler * California models also have a catalyzer in the muffler Fully Adjustable 46mm Cartridge Front Fork * Large 46mm fork tubes are extra rigid to improve handling performance on the street Bottom-Link UNI-TRAK® Rear Suspension * Extruded aluminum swingarm is lightweight and rigid * Linkage ratios offer smooth and linear suspension response * Upper shock mount is threaded for ride height adjustment Dual Semi-Floating Front Disc Brakes * The six-piston opposed front brake calipers have differential size pistons and aggressive pad material for excellent feel and bite * 300mm discus are 5mm thick to stand up to extreme use 220mm Rear Disc Brake * Small overall diameter saves weight * Lightweight, single-piston caliper produces quick, sure stops Lightweight Aluminum Perimeter Frame * Short wheelbase and steep head angle produce quick, responsive handling * Rigid design assures good handling and durability Electronic Instrumentation * The speedometer includes a coolant temperature gauge, odometer, trip meter, and a clock * The tachometer incorporates a coolant warning light Comfortable Riding Position * The most comfortable Supersport 600 period * The handlebars are an easy reach, a nice flat seat gives comfort for long rides and wide mirrors reveal more than your shoulders * The fairing and windscreen offer an easy ride with great protection from the elements Authentic Kawasaki Accessories * Including tank bra, locks, alarm, bike cover Specifications Engine: Four-stroke DOHC inline four, 16 valves Displacement: 599cc Starting: Electric Bore x stroke: 66.0 x 43.8mm Compression ratio: 12.8:1 Cooling: Liquid Carburetion: (4) Mikuni BDSR 36R Ignition: Digital Transmission: Six speed Frame: Aluminum perimeter design Rake / trail: 23.5 degrees / Front suspension: 46mm Cartridge Front Fork, fully adjustable Rear suspension: UNI-TRAK® rear linkage, 20-way compression and rebound damping, ride height adjustment Front wheel travel: 4.7 in. Rear wheel travel: 5.3 in. Front tire: 120/65ZR17 Rear tire: 180/55ZR17 Front brakes: 300mm dual hydraulic disc with six-piston calipers Rear brakes: 220mm hydraulic disc Overall length: TBD Overall width: TBD Overall heigh: t TBD Seat height: 32.3 in. Ground clearance: TBD Dry weight: 377 lbs. Wheelbase: 55.1 in. Fuel capacity: 4.8 gal. Color: Blue >wallpaper1280< >vir< lp -pero- :) PS:...glede na to, da je predelava stare nindže upejmo da bo zadeva primerno ugodna Povezava do komentarja Delite na drugih straneh More sharing options...
gregas Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 :hmm: ...ja res fajn zadevca ...sploh če bo cenovno v razredu fz6, sv650, in cbf ...če bo pa čez dva maljona kot cbr600f pol pa nou tok fajn Povezava do komentarja Delite na drugih straneh More sharing options...
premza Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 PS:...glede na to, da je predelava stare nindže upejmo da bo zadeva primerno ugodna Kaka predelava... :blink: ...to je nindža! :hmm: Povezava do komentarja Delite na drugih straneh More sharing options...
MartnKrp Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Ma kaka ninja! Ninje se zacnejo s crkami ZX... ZZ.. pa so drugi modeli... Povezava do komentarja Delite na drugih straneh More sharing options...
-pero- Objavljeno September 24, 2004 Avtor Deli Objavljeno September 24, 2004 ...evo za primerjavo nindža '02... ...zzr-ju bi lohk enojn zic dal :hmm: Povezava do komentarja Delite na drugih straneh More sharing options...
MartnKrp Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Res, da sta zlo podobna. Ampak ce bi bil ZZR res ninja, potem se ne bi imenoval ZZR, ampak ZXR ninja, ne? :D Povezava do komentarja Delite na drugih straneh More sharing options...
premza Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Res, da sta zlo podobna. Ampak ce bi bil ZZR res ninja, potem se ne bi imenoval ZZR, ampak ZXR ninja, ne? :D Zlo podobna... :lol1: Barva in črke so pa res drugačne :D Povezava do komentarja Delite na drugih straneh More sharing options...
gregas Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 (popravljeno) ...mah sam da bo pocen ...stari zx6r je bil zelo dobr konjiček Popravljeno September 24, 2004. Popravil gregas Povezava do komentarja Delite na drugih straneh More sharing options...
Thundercat Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 nič slabga ne vidim tudi če nalikuje na ninđo...je zanimiv motor... Povezava do komentarja Delite na drugih straneh More sharing options...
iurist Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Ma da nej tu kak nateg...ZZR letnik 2005 isti kt ninja let.2000 <_< mal preveč sumljivo vse skupi :hmm: Povezava do komentarja Delite na drugih straneh More sharing options...
peco Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Lepši kot letošnja Ninja sigurno. :D :D Povezava do komentarja Delite na drugih straneh More sharing options...
premza Objavljeno September 24, 2004 Deli Objavljeno September 24, 2004 Mogoče dočakamo tudi ZZR-750. Tastara ninja6 z mašina od Z750 ...pa če bi bla še v črni barvi :wub: Športna, udobna, dovolj močna, ... :notworthy: Povezava do komentarja Delite na drugih straneh More sharing options...
-pero- Objavljeno September 24, 2004 Avtor Deli Objavljeno September 24, 2004 drgač pa ne razumem zakaj so nehal prodajat GPZ500, čez lužo ga še zmer, le da je tam imenovan ninja 500 ...za okrogel miljonček mislim da bi tudi prinas kar nekaj novih lastnikov dobil... > Ninja500 '04 wallpaper< Povezava do komentarja Delite na drugih straneh More sharing options...
<=YaMaHa=> Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 Luškan motorček :D So kakšni podatki o končni hitrosti,pospešku... :hmm: Povezava do komentarja Delite na drugih straneh More sharing options...
gizmOkak Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 (popravljeno) preveč je ninji podoben :BUA: kaj so z agregata nardili itak ne vem, pomoje sam zbili en kup konju dol, pa navili na navoru na nižjih obratih...to delajo itak povsot... sam že oblika je smotana ker je od ninje <_< Na ninji je lepa :grim na ZZR niti malo :grrr vsaj kej novga bi nardili. Popravljeno September 26, 2004. Popravil gizmOkak Povezava do komentarja Delite na drugih straneh More sharing options...
gizmOkak Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 še enkrat pogledu obe slikce, pa eno čez drugo nalimu :) mopeda sta prou enaka, od nihajke do geštela, obroči itak, nosilci za tapke od sopotnika, balanca... sklopka, zavore, mah kaj čem pisat, vse je isto Povezava do komentarja Delite na drugih straneh More sharing options...
Red Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 :? Če bo to ZZR, bom pa slabe volje. Sicer dvomim, da se bo to zgodilo, ampak potem bi lahko lastniki R6 letnikov 99-02 postali novopečeni lastniki NOVE THUNDERCAT 600. Z GSX-R so po izdaji novega modela postali F šoferji? Kozlarija....ni mi všeč. Bom reku svoji - ti, ne razburjaj se, ne vozim več ninje, nič mi ne bo, zdaj mam ZZR. Halo, Kawasaki? :hmm: TO JE NINJA! Povezava do komentarja Delite na drugih straneh More sharing options...
gebre Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 Jest samo upam, da ne bo nadomestil starega zzr 600 <_< . Sicer je res, da se ne prodaja, a kaj, ko je tako lep :wub: . Povezava do komentarja Delite na drugih straneh More sharing options...
dule3 Objavljeno September 26, 2004 Deli Objavljeno September 26, 2004 Tudi ZZR 250 za ameriško tržišče je stari GPX. Kaj boljšega pa si lahko firma želi kot tržišče, kjer lahko strankam prodaja stari lager motociklov, ki jih izdelajo v drugi barvi in opremijo z drugačnimi nalepkami? Z vidika amortizacije proizvodnih orodij in proizvodnih serij je to super posel. Še pred nekaj leti so v Nemčiji prodajali GPX 600. Seveda ne z Ninja nalepkami, nemška klientela ima le malce višji IQ. Povezava do komentarja Delite na drugih straneh More sharing options...
MDR Objavljeno September 27, 2004 Deli Objavljeno September 27, 2004 Jest samo upam, da ne bo nadomestil starega zzr 600 <_< . Sicer je res, da se ne prodaja, a kaj, ko je tako lep :wub: . Se absolutno strinjam :OK: . Pa uporben je tud :notworthy: LP - M. Povezava do komentarja Delite na drugih straneh More sharing options...
Denny Objavljeno September 27, 2004 Deli Objavljeno September 27, 2004 nekje sem prebral, da naj bi prišel kmalu manjši brat ZZ-R 1200...no potem bo to pravi zz-r Povezava do komentarja Delite na drugih straneh More sharing options...
Red Objavljeno September 28, 2004 Deli Objavljeno September 28, 2004 (popravljeno) Po moje bi blo boljše, če bi ga naredili po vzoru večjega ZZR-1200 - minilo je nekaj časa, ampak vseeno se mi zdi boljša varianta kot ZX6R 2000-2002. Slednji je absolutno odličen moped, ampak ob vseh novostih se mi to zdi kiks za Kawasaki - supersport motocikli so na žalost tisti, ki se najhitreje in prehitro starajo... :wacko: Pomanjšan 1200 se mi pač zdi bolj primeren, sem za zelene in menim, da "stara" roba ne spada več v njihovo paleto. Če bo pa čez lužo tak, kot kaže novička, pa zastonj psiharim. :hmm: LP, Red. Prodam ZX6R ali pa ZZR 636 :P , l. 2002, pohitite, ekluzivno... :kva2: :OK: Popravljeno September 28, 2004. Popravil Red Povezava do komentarja Delite na drugih straneh More sharing options...
Tomozuki Objavljeno September 28, 2004 Deli Objavljeno September 28, 2004 Mah, to so neke ameriške finte, ker oni čisto drugače poimenujejo vse to. Za njih so vse Kawe Ninje, sej prejšnji ZZR je tut imel Ninja nalepko pa GPZ... To je vse en jajc ;) Povezava do komentarja Delite na drugih straneh More sharing options...
Red Objavljeno September 28, 2004 Deli Objavljeno September 28, 2004 Mah, to so neke ameriške finte ... To je vse en jajc ;) :OK: Strinjam s tabo... si lepše zadel bistvo :grim Povezava do komentarja Delite na drugih straneh More sharing options...
