R O T A S
O P E R A
T E N E T
A R E P O
S A T O R
Popravljeno . Popravil rebel
to naj bi bilo skrito noter
pojma nimam zakaj se gre mi lahko to mal bolj razlozis :? :D
The Latin Square is an intriguing example of a transposition cipher. It is made up of a series of 5-letter words arranged in a square, found on the walls of Roman villas in Pompeii and Cirencester.
The square reads 'rotas opera tenet arepo sator', which roughly means 'he who guides the plough sows the seed'. You might notice that the square is highly symmetrical - it can be read left to right, right to left, upwards or downwards.
However, this harmless symmetrical motto disguises a much more important message, which can be found by transposing the letters.
After rearranging the letters in the latin square we have:
1. 'Paternoster' repeated twice, which means 'our father'
2. The paternosters form a cross, which has Christian significance.
3. Left over are A's and O's, representing the alpha and the omega, the beginning and the end, also of Christian significance.
It is thought that the Latin Square was put on the side of houses which offered refuge to Christians, who were the only people who knew how to transpose the letters and obtain the real meaning of the square.
Strangely, some historians think that the Latin Square is even older than the Christian Church.
Sounds kul.
se pravi..
-bereš enako v 4 smeri..
-še vedno ni določen natančen pomen
-pisava na kamnu naj bi bila starejša od krščanstva (slika ni pravi kamen)
-kristjani naj bi to geslo uporabljali za obrede ali pa naj bi bilo na hišah ki so ponujale prenočišče vernim in samo oni naj bi vedeli za kaj se gre
-nekdo je vn potegnu besedo a..o paternoster...(alfa, omega, oče naš)
alfa omega naj bi pomenila začetek konca ne..
-dobesedno pa je prevod- Arepo the sower holds the wheels at work
-skratka cel čudež.......
:book:
ma zadeva mogoče kaj zveze z rotarijanci?
Še vedno ne vem kaj naj bi blo to ,,oh in ah,, oz. kaj bi rad s tem povedal? A da bi krščanstvo to povzel...tako kot so povzeli marsikaj iz prejšnjih verovanj se ti pa ne zdi omembe vredno...sej nima veze, še vedno ne vidim čudeža....razloži in mogoče tudi jest zrno najdem.
ja zdej pa ne vem kdo so bli to....
ja ne vem no, to je famozni magični kvadrat.. meni je zanimivo
mah...to je tko kot kaki rebusi in premetanke v kakšnih križankh....preveč časa v glavnem ...ja sej je zanimivo...že takrat so obstajali raznorazni xx(zdej se ne spomnem kdo je ta ki mu non stop po glavi sam to hodi...ima tak specifičen glas in svojo oddajo na radiu (no vsaj imel jo je) in tut po tv je bil in moril ljudi z raznoraznimi anagrami in podobnim.
Zadeva sicer datira pred Kristusa, tale Pater noster, o katerem je beseda v anagramu, pa naj bi bil bog Mitra, zaveznik dobrega in borec proti zlu ... Imel je levjo glavo itd...
