Broj Jedan Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 Pravkar sem dobil tole opozorilo od bratranca v GB kjer policija opozarja na nov stil kraje vozil. Prosim, da besedilo skopirate in ga preko mailov in forumov čimbolj razširite med ljudmi. Vsekakor, kot boste videli, ne gre za šalo. Vozila kradejo s kosom papirja katerega zataknejo na moteče mesto .. :::::::::::: kopija :::::::::::::::::::::: CAR OWNERS AND CAR DRIVERS PLEASE READ THIS WARNING!!!! Be aware of new car-jacking scheme. You walk across the car park, unlock your car and get inside. Then you lock all your doors, start the engine and shift or put into reverse. You look into the rear-view mirror to back out of your parking space and you notice a piece of paper stuck to the middle of the rear window. So you shift the gear stick back into park or neutral, unlock your doors and jump out of your car to remove that paper or whatever it is that is obstructing your view. When you reach the back of your car that is when the car-jackers appear out of nowhere, jump into your car and take off!! Your engine was running, you would have left your purse in the car and they practically mow you down as they speed off in your car. BE AWARE OF THIS NEW SCHEME THAT IS NOW BEING USED IN GLASGOW AND MANCHESTER AND IS MAKING ITS WAY ACROSS THE COUNTRY! Just drive away and remove the paper later! Forward this to friends and family especially to women! A purse contains all your identification,and you certainly do NOT want someone getting your home address - they already have your keys!!! JUST BE AWARE AND TAKE CARE IT WILL PROBABLY SOON ARRIVE IN YOUR AREA
Čamac Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 (popravljeno) Eni se znajdejo :D Čeprav na grd način :BUA: Popravljeno Januar 2, 2007. Popravil Brodar
lina Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 Čist tko....kako pa frajerju uspe odparkirati avto v sekundi, če si že kot lastnik nisi mogel iz parkplaca ker te je oviral nek papir? No ja...men se tega ni za bati, ker ne vem zakaj bi si človek nakopal stroške za reciklažo. :blush:
Broj Jedan Objavljeno Januar 2, 2007 Avtor Objavljeno Januar 2, 2007 (popravljeno) No ja...men se tega ni za bati .. Hja lopovi danes tudi malo premislijo zadevo, opazujejo "stranko", izberejo pravo kanto, parkirano tako, da je zadevo mogoče odpeljati .. Zelo verjetno se ne bodo spravljali na dvainpolmetrske bodibojlerje tipa Arnie, ampak na malce raztresene gospe v dragih avtih, ki se iz čiste nadutosti parkirajo tako, da ovirajo vse samo, da lahko veleone odpeljejo brez težav .. .. potem pa lump odpelje brez težav .. :angry: Popravljeno Januar 2, 2007. Popravil Broj Jedan
JeRn3j Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 (popravljeno) Mah ja... to rata 1x na 10000 poskusov .) moje mnenje Popravljeno Januar 2, 2007. Popravil JeRn3j
_ales_ Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 (popravljeno) no ja... :slap: eni se pač znajdejo čeprau na grd način Popravljeno Januar 2, 2007. Popravil PESHY BOY
lina Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 dvainpolmetrske bodibojlerje tipa Arnie, pa to sem jaz :P ampak na malce raztresene gospe v dragih avtih, ki se iz čiste nadutosti parkirajo tako, da ovirajo vse samo, da lahko veleone odpeljejo brez težav .. Torej ne bom poslala tega raztresenim bogatim, nadutim, gospem...nej tečejo za storilci pa pol do policaja in prijavijo krajo (mobitel bo itak poleg zlate Vise v torbici na prvem zicu), bojo imele vsaj kaj lajat v wellnes centrih. :ninja:
gizmOkak Objavljeno Januar 2, 2007 Objavljeno Januar 2, 2007 (popravljeno) ampak na malce raztresene gospe v dragih avtih, take pa itak ne vejo kaj so špegle, tako da tudi listka ne vidijo :headbang: ha, pr meni to ne pali, k preden sploh odklenem avto pogledam po šipah, če nimam reklam gor... tako da popušil je na to tehniko :grrr majo pa zanimive tehnike te lopovi :grim Popravljeno Januar 2, 2007. Popravil gizmOkak
Broj Jedan Objavljeno Januar 3, 2007 Avtor Objavljeno Januar 3, 2007 .. majo pa zanimive tehnike te lopovi :grim upal sem, da bo kdo opisal še kakšno drugo .. pa vse kaže, de ne bo nič .. :(
JAZBEC Objavljeno Januar 3, 2007 Objavljeno Januar 3, 2007 Hja Zelo verjetno se ne bodo spravljali na dvainpolmetrske bodibojlerje tipa Arnie, ampak na malce raztresene gospe v dragih avtih, ki se iz čiste nadutosti parkirajo tako, da ovirajo vse samo, da lahko veleone odpeljejo brez težav .. .. potem pa lump odpelje brez težav .. :angry: ...al pa na bjonde k jim je dragi, ki še spi po sladki noči dal ključe od avta da skočijo po jutranji zajtrk :D ..
gizmOkak Objavljeno Januar 3, 2007 Objavljeno Januar 3, 2007 upal sem, da bo kdo opisal še kakšno drugo .. pa vse kaže, de ne bo nič .. :( če bi se s tem ukvarjal bi ti kej povedu... al pa najbrž bi bil tiho tko k večina :hmm: -cajte nazaj so baje d lagune odklepali z uni TV dalinci... informacija by baba čula baba rekla... -marcedese tako, da so vrgli en časopis pod podvozje in zakurli... senzorji za dim so zaznali in hopla, avto se je oklenu...bedasta fora, baje d je delalo :?
