Kripto Objavljeno Avgust 18, 2007 Deli Objavljeno Avgust 18, 2007 Rabim nov variomat in me zanima kakšnega kupit? Skuter pa je takšen: Model Number: YY50QT-6 EC Certificate Number: e4*2002/24*0714*00 Length(mm): 1730 Width(mm): 680 High(mm): 1180 Wheel base mm: 1265 Minimum clearance from ground(mm): 110 Dry weight (kg): 90 Maximum load mass (kg): 240 Maximum speed (km/h): 45 Front/rear tyre: F: 120/70-12 R: 130/70-12 Brake system: Disc/Drum Engine: BZ139QMB Maximum power/rotate speed kW/(r/min): 2.2/7500 Starting way: Electric/Kick start Ignition System: C.D.I Fuel tank capability (L): 5 Enginetype: 4Stroke,Single,Air-forced cool Povezava do komentarja Delite na drugih straneh More sharing options...
