Miha27 Objavljeno September 13, 2008 Deli Objavljeno September 13, 2008 (popravljeno) Features - All-new full-sized 125 cc Supermoto Punchy liquid-cooled 4-stroke 4-valve single cylinder Fuel injection Powerful large-diameter disc brakes 17-inch Supermoto-style wheels Engine - Engine type Liquid-cooled, 4-stroke, forward-inclined single cylinder, 4-valves, SOHC Displacement 124.7 cc Bore x stroke 52.0 x 58.6 mm Compression ratio 11.2 : 1 Maximum power 11 kW (15 PS) @ 9,000 rpm Maximum torque 12.2 Nm (1.24 kg-m) @ 8,000 rpm Lubrication system Wet sump Fuel System Fuel injection Clutch type Wet, multiple-disc coil spring Ignition system TCI (digital) Starter system Electric Transmission system Constant mesh, 6-speed Final transmission Chain Fuel tank capacity 8.5 L Oil tank capacity 1.15 L Chassis - Chassis: Steel double cradle Front suspension system Telescopic forks Front travel 240 mm Rear suspension system Swingarm (link suspension) Rear travel 230 mm Caster angle 25.5º Trail 78.5 mm Front brake Single disc, Ø 298 mm Rear brake Single disc, Ø 220 mm Front tyre 110/70-17 M/C 54H (tubeless) Rear tyre 140/70-17 M/C 66H (tubeless) Dimensions - Length 2,095 mm Width 835 mm Height 1,165 mm Seat height 920 mm Wheel base 1,430 mm Minimum ground clearance 255 mm Wet weight 137 kg Popravljeno September 13, 2008. Popravil HostMaster Povezava do komentarja Delite na drugih straneh More sharing options...
Miha27 Objavljeno September 13, 2008 Avtor Deli Objavljeno September 13, 2008 (popravljeno) Okvirna cena od 3000-max. 3700€, dobava dugo leto Februarja , rezervacije sprejemajo januarja 2009. Vir: Yamaha KMC LP Popravljeno September 13, 2008. Popravil HostMaster Povezava do komentarja Delite na drugih straneh More sharing options...
_LuX_ Objavljeno September 13, 2008 Deli Objavljeno September 13, 2008 tema že obstaja Povezava do komentarja Delite na drugih straneh More sharing options...
Miha27 Objavljeno September 13, 2008 Avtor Deli Objavljeno September 13, 2008 tema že obstaja jst je ne najdm ?? Povezava do komentarja Delite na drugih straneh More sharing options...
_LuX_ Objavljeno September 13, 2008 Deli Objavljeno September 13, 2008 http://www.motosvet.com/tabla/index.php?showtopic=27773 Povezava do komentarja Delite na drugih straneh More sharing options...
Miha27 Objavljeno September 13, 2008 Avtor Deli Objavljeno September 13, 2008 Moderator prosim da temo izbrišeš! Hvala! Povezava do komentarja Delite na drugih straneh More sharing options...
Roky Objavljeno September 13, 2008 Deli Objavljeno September 13, 2008 Moderator prosim da temo izbrišeš! Hvala! Jp. Povezava do komentarja Delite na drugih straneh More sharing options...
