Ducati Sportclassic
Ducati je na tokijskem salonu predstavil družino konceptnih motociklov, ki so jih poimenovali DUCATI SPORTCLASSIC.
Študije modelov PAULSMART 1000, SPORT 1000 in GT 1000 se spogledujejo s klasičnimi Ducatiji iz začetka sedemdesetih let (prvi po Ducatiju 1974 Supersport 750, drugi po 1973 Sport 750 in tretji po 1971 GT 750).
PAULSMART 1000
Tehnične specifikacije
ENGINE
Type L-twin cylinder, 2 valve per cylinder Desmodromic, air cooled
Displacement 992 cc
Bore x Stroke 94 x 71,5 mm
Compression Ratio '10:1
Gearbox 6-speed
*Power 62 kW - 84 CV @ 8000 giri/min
*Torque 84 Nm - 8,5 Kgm @ 6000 giri/min
Fuel injection Electronic fuel injection, 45 mm throttle body
Exhaust Black exhaust system with two steel mufflers r.h.
Emissions Euro 3
CHASSIS
Frame Tubular steel trellis frame
Wheelbase 56.1 in
Rake 24°
*Steering angle 30° right and left
Front wheel travel 4.7 in
Front wheel Spoke wheel, 3.50 x17
Front tyre 120/70 ZR 17
Rear suspension 1 monoshock l.h.
Rear wheel travel 5.1 in
Rear wheel Spoke wheel, 5.50 x 17
Rear tyre 180/55 ZR 17
Front brake 2 x 320 mm semi-floating discs, floating caliper 2-piston, 2-pad caliper
Rear brake 245 mm disc, 2-piston caliper
Weight * 425 lbs
Max Length 82.7 in
VERSIONS
Tank and fairing Colours metal flake silver
Frame and wheel colours Frame: blue wheels: aluminium
Versions one-seat
*Estimated values
le kej jim je blo da so to nardil :?
kao oldtimer z moderno tehniko :hmm:
SPORT 1000
TEHNIČNE SPECIFIKACIJE
ENGINE
Displacement 992 cc
BorexStroke 94 x 71,5 mm
Gearbox 6-speed
*Power 62 kW - 84 HP @ 8000 rpm
*Torque 84 Nm - 8.5 Kgm @ 6000 rpm
Emissions Euro 3
CHASSIS
Wheelbase 56.1 in
Rake 24°
Weight * 423 lbs
Max Length 82.7 in
VERSIONS
Tank and fairing Colours Burnt yellow
Frame and wheel colours Frame: black/ wheels: aluminium
Versions one-seat
*Estimated values
GT 1000
ENGINE
Displacement 992 cc
Gearbox 6-speed
*Torque 84 Nm - 8.5Kgm @ 6000 rpm
Exhaust Chromed exhaust system
Emissions Euro 3
CHASSIS
Wheelbase 56.1 in
Rake 24°
*Steering angle 32° right and left
Rear suspension 2 side shocks
Weight * 423 lbs
Max Length 82.7 in
VERSIONS
Tank and fairing Colours GT grey
Versions two-seat
*Estimated values
ko vidim tak motor, si mislim
mar so res prišli časi, ko je motor le še sredstvo izključno za postavljat se
ja, in to že dolgo
zanimivo, grmeči V-twin (če s pravim avspuhom) ujet v obliko kitajskih mopedov in up to date opremo
niso mi všeč, razen ta prvi, ki je pa res stara šola tekmovalnih oblik
Meni sta pa sport 1000 pa gt 1000 všeč
men so pa vsi trije lepi,mogoče gt1000 mal cenen deluje ampak drugač pa bi imel vse :D
samo cena bo pa po moje ducatiju primerna :)
ne vem v cem je fora teh motorjev... :hmm:
to je pomoje namenjen precej starejsim motoristom ki se radi spominajo starih casov. ne vem jes ga ne bi nikol imel
ma kr neki...
Ne samo za stare motoriste.... retro... klasika... obline starih motororjev...
prekrasne lepote... imajo pa nove zmogljive motorje v starem stilu.
to je nekaj čudovitega
evo še en primer, ki se meni zelooo dopade!!
evo...še lepotec od zadaj
pa še primerna čelada (na starem 900 SS-u)
WTF???
:blink: :o :blink: :o :blink: :o :? :? :? :? :? :? :? :hmm: :hmm: :hmm: :lol1: :lol1:
Krasni motorji. Večna klasična lepota z modernimi zmogljivostmi. Supaaaaa! :OK: :OK:
... samo kupoval jih ne bo nobeden. Razen Američanov, ki so fliknjeni na starine (ker svoje zgodovine nimajo).
..samo kupoval jih ne bo nobeden..
..ne, ceco, nobeden jih ne bo kupil.. prav imaš... samo hondini čoperji bodo šli v promet <_<
sicer je pa sport 1000 prav srtčkana zadevca.. tisti špegli malce motijo (pa kardana ni :naughty: ), drugače pa je prav hudi.. je pa res, da vsaj prva dva verjetna tangirata predvsem na kao nastopaško publiko, ki je pa niti ni malo, zato bo po moje zadeva šla kar fajn v prodajo..
kljub temu pa o amerih delim podobno mnenje (da se ne bo zdaj bojišče odprlo :yea2: )
Popravljeno . Popravil spilferderber
se najde tudi kak drugi ki se bo zaljubil v tako zadevo....američani so pa posebneži ni kaj....
Meni grdi vsi trije. :cry: Kar se tiče take eksotike(beri italjanov) ga ni čez MG V11 Scura .Vsaj kar se nakedov tiče:notworthy: Tisto je pa res lepota
Še ena študija...........kako za velke dnarje prodat stara jajca (beri zastarelo tehniko)!! :D :P :o :hmm: :BUA: :BUA: :BUA: :BUA: :BUA:
meni je pa predvsem prvi blazno všeč, edino malo "švoh" je mašina, lahko bi dali od 999 mašino pa da je pol pravi racer.
glede pozerstva pa,............... a drugi novi motorji pa zgledajo blazno ne-pozersko (vsi cestaki, po možnosti še replica barve, da o čoperjih sploh ne začnem)?
no lepo da ducati malo iz zgodovine črpa navdih, meni so itak stari motorji oblikovno bol všeč, nekaj jih je bilo fenomenalnih.
meni je tudi lepo pogledat kak tak motor...recimo Yamaha Fjr 1100/1200 letnik 82....ta oblika mi je tako všeč da če bi naredili čisto kopijo motorja bi ga takoj vzel....sej so neki moderni stroji podobni ma to ni to....sicer pa je to relativno mlada oblika ki se kaže v modernih motorjih..
Ostanimo pri teh ta novih Ducatijih... Drugače pa, kot je Ceco napisal nekje drugje, se je na veliko začelo "testiranje" kupcev s "študijami". Mimogrede, na linku, ki je na prvi strani (na Ducatijevi strani) lahko sami oddate mnenje kaj točno vas na motociklih moti/vam je všeč/koliko bi plačali za njih itd... (Če bi kdo blazno rad sodeloval pri razvoju Ducatija) :D
men zgleda kot eno skopodralo -> ni ne star ne nov rahlo smesen motor z najnovejsimi vilcami in diski :( :)
Posrecen na nek nacin tudi ponesrecen :hmm: :?
