Yamaha FZ 6
...evo... uradno poročilo z predstavitve naslednika popularnega FZSja 600, po predvidevanjih ne gre za nadgradnjo ampak za popolnoma nanovo zasnovan motocikel, ki ima po tehnološki plati zelo malo skupnega z predhodnikom (zato mislim da si tako kot novi tdm in nova ninja zasluži svojo temo) Celotno poročilo si lahko preberete >tukaj< ene par alinej in slikce pa sem pripopal tukaj...
TECHNICAL HIGHLIGHTS
--ENGINE
R6 derived engine, re-tuned for greater mid-range acceleration
600cc liquid-cooled 4-stroke forward-inclined in-line 4 cylinder, DOHC 16 valve
72 kW (98 HP) @ 12,000 rpm
63.1 Nm (6.4 kg-m) @ 10,000 rpm
Group injection type fuel injection system
High efficiency 4-into-2-into-1 ‘up muffler’ exhaust
R6 gearbox ratios with modified secondary reduction ratio
R1-type downdraft intake
Air induction system
Integrated immobiliser system
Honeycomb catalyser
Greatly exceeds EU-2 emission standards
--CHASSIS
Flat handlebars
Forward leaning sports riding position
Aggressively styled headlight
Two-piece weld-free aluminium die-cast frame
Extra-long box-section aluminium swingarm
Repositioned crank axis
New dual seat with riding position moved forwards
Fazer 1000-style 43mm front forks
High performance front braking system with dual 298mm diameter front discs
245mm diameter rear disc with Nissin top-mounted caliper
Lightweight R6-type 5-spoke wheels running wider rubber
70&ordm; lock-to-lock turning angle
Sophisticated new LCD meter panel
Ergonomic 19 litre alloy fuel tank
--COLOURS
Lava Red
Midnight Black
Silver Ice
TECHNICAL SPECIFICATIONS
--ENGINE
Type Liquid-cooled, 4-stroke, forward-inclined,
in-line 4-cylinder, DOHC, 16 valves
Displacement 600 cc
Bore and Stroke 65.5 x 44.5 mm
Compression ratio 12.2 : 1
Max. Power 72 kW (98 HP) @ 12,000 rpm
Max. Torque 63.1 Nm (6.4 kg-m) @ 10,000 rpm
Lubrication Wet sump
Fuel supply Group injection type fuel injection
Clutch type Wet, multiple disc
Ignition TCI
Starting system Electric
Transmission Constant mesh, 6 speed
Final transmission Chain
Gear ratio 1: 2.846
2: 1.947
3: 1.556
4: 1.333
5: 1.190
6: 1.083
Primary reduction ratio Primary reduction ratio 1.955
Secondary reduction ratio Secondary reduction ratio 2.875
--CHASSIS
Frame Aluminium die-cast frame
Front suspension Telescopic fork, &oslash; 43 mm
Rear suspension Swingarm (Linkless type Monocross)
Front wheel travel 130 mm
Rear wheel travel 130 mm
Caster angle 25°
Trail 97.5 mm
Front brake Double discs, &oslash; 298 mm
Rear brake Single disc, &oslash; 245 mm
Front tyre 120/70 ZR 17 M/C (58W)
Rear tyre 180/55 ZR 17 M/C (73W)
Rim size front 17 x MT3.50
Rim size rear 17 x MT5.50
--DIMENSIONS
Overall length 2,095 mm
Overall width 750 mm
Overall height 1,215 mm
Seat height 795 mm
Wheelbase 1,440 mm
Min. ground clearance 130 mm
Dry weight (FZ6 Fazer) 187 kg
Dry weight (FZ6) Not known at time of printing
Fuel tank capacity 19 litres (reserve 3.5 litres)
Oil (tank) capacity 3.4 litres
Lp -pero- :)
  • Ni mi všeč 1
No ja! Zdaj vsaj vemo koga si je Yamaha izbrala za direktno konkurenco oz. kdo jim odžira velik kos pogače (luč, izpuh, varijanta brez maske.....). Drugač pa jo je Motorrad že vozil (v sredo že čitam test - :P hahahaha :D - ni reklama, hočem vzbuditi malo nevoščljivosti ;) ). Na slikah pa zgleda ko "JEDERMANS LIEBLING". Upam, da bo cena podobna stari !?!
LP Bajsi B)
  • Ni mi všeč 1
A mogoče kdo ve kdaj bo naš uvoznik kaj več vedel? Kako je bilo s tem do zdaj? Gdaj ga je najbolje naročiti, da ne čakaš na njega pol sezone? Je ob naročilu potrebno kaj plačati?
Nove FZ6 naj bi bile naprodaj že jeseni.
Ob naročilu je običajno potrebna ara, recimo 100 jurčkov, ostalo ob prevzemu motorja.
Hola!
V zadnji številki Motorrada (18/2003, 14. avgust), kjer sta oba nova modela predstavljena piše, naj bi bil FZ6 Fazerja le malo dražji od zdajšnjega modela (ki stane tam 6990 €, kar znese trenutno 1.628.670 SIT), naked pa najbrž, kot ponavadi, nekaj sto € manj. Živi bili pa vidjeli...
tomidelipress....sem vedel, da moram počakat z nakupom motorja :P :P B)
Jeba pa bo, če bo cena narasla, ker bo potem konkurenca prišla v poštev...kar bo grozno :blink: :lol: ;) predvsem zame...kaj čem...yamaha mi je všeč B)
Skratka, v rokah imam eno lično 62-stransko brošurco, ki je namenjena samo tanovi FZ6, zraven pa še cede z mega-vlkimi slikcami in teksti ... :)
Kje si staknil tole brošurico pa CD? Jst bi se tud mal slinil :P :D
Al se sam men zdi al pa japonci spet italjanske detaile kopirajo (števc, prednja luč pri naked izvedbi in še kakšen detail)!
Sorry Sprednja luč je bila na japoncih že vsaj ob dveh priložnostih predstavljena, ... pobrskaj malo po Yamahini strani in boš našel taisto luč (za detajle ne trdim) na prototipu MT01 iz leta 1999 in prvi showroom predelavi Bulldoga iz 2001 ali 2002.
Hmmm kaj je s števcem?
No ja ..... Rižkoti vračajo udarec. :lol: B)
Še nekaj slikc...
...mal bolje opremljen...
...closeup riti...
...od zadaj levo...
...direkt...
...pa še en volpejpr...
...čau :)
...aja še nagec...
...oba...čeprav mislm da so tri farbe...
...carving...
...diablo...
...učk...
...števc čez dan...
Ena po mojem okusu...
Popravljeno . Popravil premza
Zadaj je tud lep seveda.Vendar bo uprašanje kakšen glas bo dal od sebe,kajti če bo tako kot pri zdejšnih fzs,bo bolj žalost,poleg tega pa dva avspuha pomeni še enkrat večji strošek pri menjavi iz org na wingsa ali akrapota.Tako da bo sigurno manj menjave,kot do sedaj ko ima svaka tretja fzs wingsa gor.
...pa ker norc bo menjal to divoto...
...jebiga štirivalniki visoko pojejo, sam pomoje to ni kriterij pri nakupu tega motorja :)
Tole...
...je pa prvi motorček, za katerega bi reku da bi ga imel raje kot TDM900,
ki je bil do sedaj moj "dream-bike". Tud če bi mel 2.5mio za nakup
motocikla in nebi rabu keša za kej druzga bi vrjetn raj tole kupu, jebiga.
Tud mene zanima cena.Upam ,da se bo dal dobit v modri barvi. :D
:( --COLOURS
Lava Red
Midnight Black
Silver Ice
Mogoče pa bojo tud modro naredli B)
:( --COLOURS
Lava Red
Midnight Black
Silver Ice
...to so barve za naked, za poloklep bo namest črne modra
Včeri sm v knižnci mal revije bral, pa je v eni nemški pisal (nevemkeri sm jih mel tolk na miz), da so pr jamahi izjavl, da so se mal zajebal, da so prehitr dal vn naslednika fzs600, ker bi lahko fzsja še vsaj en let prodajal k vroče žemlce ker je bil itak pred konkurenco(hornet, bandit, sv, zr) zdej pa je sploh svetlobna leta pred drugimi in svojim predhodnikom in en yamahin inžinir je izjavu, da je fzs zelo dobr motor ampak da je razlika v rimerjavi z fz6 taka kot med golfom 2 in 5, ker je baje fzs v osnovi nespremenjen od l.96(nism zihr) k je pršou vn, fz6 pa je narejen in nafilan z najnovejšo tehnologijo ...za mal kasnej predvidevajo tudi fzs-ja z abs‚
glede litrskega fzja pa nč nočjo rečt, novinar predvideva da ga bodo nasledn let še prodajal tako kot letos fzs600, da spucajo skladišča pol pa ....
Evo saj ene par mau bl spodobnih slikc od tanove fazerke, ostalo mrbit jutr med informatko :rolleyes:
ejga Sym a bi ti lohka guno ce-dejko nekam uploadow da bi poj to jest dol sneu?može?
LP by gebre
Sam, spet ta zadnja nihajka :hmm: , lohk bi jo mal bolj obdelal, kot okwir npr.....
Če bo kej tacga naslednja tisočica :yea2: :yea2: :yea2: ...
Zadnja nihajka BTW ni prav enaka kot pri FZS600, saj je nekaj centimetrov daljša.
Prednje vilice pa so enake, kot trenutno na fazerki 1000, 43-milimetrske in nastavljive po treh parametrih.
Dva volpejpra...
tuki je pa še uradna yamahina galerija, sam je server tok zaseden da se men ful dolg nalaga :D
tuki je pa 3D view modrga in srebrnga
najlepš jo bo na cesti vidt tako.....
